serpentine belt
cobrakidd03
michigan
I replaced my serpentine belt 2 weeks ago because it was squeeling bad!! The noise went away for about a week and now its back!! What is causing this? Help:banghd:
hawkeye18
Sorta cares
Norfolk, VA
Bad tensioner (ATX) or incorrectly set tension (MTX).
Or, a faulty pulley, but if it went away for a week I wouldn't put money on it.
cobrakidd03
michigan
ok thanks everyone. I will replace the tensioner. also I noticed that my AC compressor does not turn when the AC is on, should I be concerned about it messing with the belt?
hawkeye18
Sorta cares
Norfolk, VA
Listen to this man, he speaks the truth.
He's also totally hot, like OMG :***:
you got that right, grrl!
Nah, chances are close to 90% the clutch has too big a gap. It's happened at some point on every SHO I've come across. The gap is set with shims; you will have to remove the clutch face (you'll need a spanner wrench and, I wanna say, a 13mm deepwell socket. It might be 12mm... also a set of good snap ring pliers) and remove shims as necessary to get the correct clutch gap. I used to know the gap off the top of my head... I wanna say .023-.032 inches. It's on the forum, though, do a search for it.
cobrakidd03
michigan
Kind of an update to my belt. Last night I started the SHO and for the first few mins the belt was quiet. Then it started to chirp a little bit. Got quiet again, so I thought great is shut up. The I gave i reved it up a bit and started making its noise again. Is this still the tensioner?
SeanMc
NoMoSHO
Yes...(dots added to please the SHOForum Masters)
Try some belt dressing just to make sure it is the belt before you try anything else, Money wise.
You should never use belt dressing on a serpentine belt. Maybe some soap and water to try and clean it.
hawkeye18
Sorta cares
Norfolk, VA
Put a wanted ad in the WTB section - I am SURE somebody has a spare one. If I had one I'd give it to you!
shoon
cliTaurus
Dawson Creek, BC
Clutch air gap Specification:
0.45 - 0.85mm (0.018 - 0.038 inch)
hawkeye18
Sorta cares
Norfolk, VA
Well ****, I was inside the spec. You'll want to set it on the low end of the range to maximize the amount of time before you have to reshim it again...
myculito
