captinsho
SHO nuff
Okay any help I can get here would be greatly appreciated. I am a member of the Delphi Sho forum and was told you guys reaaly know your stuff, so I could use some of that stored up (definitely not useless) info. I have a 94 MTX w/96k. Lately is has been misfiring. My check engine light has been on also. I ran the codes and I got 1: KOEO I GOT CODE 126 (MAP OR BARO SENSOR OUT OF RANGE) AND CODE 219 (SPOUT CIRCUT FAILURE, TIMING DEFAULTED TO 10 DEGREES-FOLLOW CODE 213 DIAGNOSIS) 2: KOER CODE 111 (SYSTEM CHECKS OK). My brother took the car (knows more about engines than I do plus has a shop to work on them) and reconnected something I must have missed when I did a clutch job a couple of months ago. My check engine light went off after that but it still ran poorly. Next he pulled the plugs and noticed that all the electrodes on my 5 month old BOSCH platinums were "burned" off. He said he had the same problem on a set of BOSCH platinums he put in an ****** GT he owns and he has heard that some Ford engines have problems with BOSCHs. Anyway I bought new platinums (Chapions) and it made a little difference but it is still definitely not right. We also reset the computer. I plan to run the codes again and see what/if I get. I also brought the car to a local Ford dealer about 2 months ago and they got two codes: MAF hard default and air charge sensor error. Neither of these came up when I ran the codes. One possible explantation to that may be because after the Ford dealer looked at it I swapped out my Pro Flow 80mm MAF and put the stock one back in. Since I ran the codes myself I put the Pro Flow back in. Does not seem to matter if I have the stock MAF or the Pro Flow in... either way it acts the same. It is funny becuase if I rev the engine (like past 3K) and accelerate moderatley it will run strong, sometimes I can even put some real petal into it and it wont misfire but if I put a little too much petal into it it spits and back fires. Aslo it doesn't idle perfect. It will idle OK then it will start to misfire/backfire and die (sometimes) if it idles for too long... like 2 to 3 minutes. When I accelerate from a dead stop very slowly it is OK, but I have to acclerate too slowly to enter into traffic. Also if it starts to misfire it will misfire through the entire RPM range and can get very rough if I try to put any petal into it.Not sure if someone has some ideas. I would greatly value any input I could get! Gas is up to almost $2 per gallon (for premium) and I am getting about 10 to 12 miles per gallon. Also it is very annoying to have this much power under the hood and be the slowest car pulling away from a red light (while I sputtter and back-fire). Thanks in advance for your help.
