SCT BDX general error 110D8
citysmoke
Chicago
Just got around to installing my AO tune and got this general error code from the BDX 110D8 .:mad: Any help with this would be appreciated.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Make sure that all interior and exterior electronics are off or unplugged. AC, headlights, radio, radar detectors, sub amps, everything. If the SCT detects a voltage drop of more than 0.2v during the process it will abort to prevent bricking the pcm.
citysmoke
Chicago
Thank you I will go back out there and make sure all are off and try again(fingers crossed).
FiveLeeter918
Tulsa, OK
if the car has been sitting for a bit prior to tuning, I've also found that starting the car and letting it idle for a few minutes, then turning it off and immediately tuning helps as well.
citysmoke
Chicago
My dash cam kept turning on during the process causing the voltage drop:confused: . Car is now up and running thanks again:finger:
