Scary Moment
The SHO
I was out yesterday and stopped for like 10 minutes somewhere and when I got back into my SHO to leave, I turned the key, and all the electronics freaked out for a second and then everythign went dead. Probably 5 minutes later, everything started up and I drove off like nothing ever happened. Is this the CID?
The SHO
all the lights on the warning light row flickered, climate control flickered and sputtered to come on, engine bucked 4 or 5 times then shut off, stereo shut off...
morpho18
Des Moines, Iowa
Thirded! My car did the EXACT same thing - negative battery cable came loose and was just sitting on top of the post. when i gave it gas, the momentum of the car would make the cable lose contact with the post and it would "freak out".
SHOtimer
#2910
Santa Clarita, Ca
I would check all the connections and take the battery and alternator in to have them tested, and replace the offending parties..
Doug
The SHO
I just bought an optima red top and I'm going to go install it. Hopefully that will clear up the problem.
The SHO
Problem solved. Only the stock battery tray doesnt hold the optima very well? Any suggestions?
