Vinracer1
Im creating a vintage off road Ford Ranger for NORRA. its a vintage racer for the Safari class. not may transmission options indeed, as I would like to have the C4 to it to keep it simple, but no bellhousing exists for it.
So the M50D-R1 is the closets match to the sho engine.
I have used research and Claude and Chat to create a build list of parts using the following - but if you look I need to figure out the pilot bearing. Anybody have any thoughts of what the dimension are for the pilot bearing.
Posting all the details here so it can be helpful for tothers doing the same.
Here is a photo of the truck -
Initial design:
Clean the crankshaft flywheel ******. Inspect the crank ******, threads, and rear main area. Remove all burrs and contamination.
STEP 2 — PREPARE/INSTALL PILOT BUSHING
Machine the custom bronze pilot bushing from verified crank-bore and M5OD pilot dimensions. Press it squarely into the crank using a proper driver. Do not hammer directly on the bushing.
STEP 3 — INSTALL SHO FLYWHEEL
Install the SHO flywheel using the correct crank bolts and specified thread treatment. Tighten progressively in a star/cross pattern to the applicable Ford specification.
STEP 4 — CHECK FLYWHEEL RUNOUT
Install a dial indicator and check flywheel face runout. Target approximately 0.005 in. TIR or less unless the applicable Ford/SPEC specification requires a tighter limit. STOP if excessive.
STEP 5 — INSTALL MCLEOD 260527 DISC
Place the disc on the flywheel. Confirm correct orientation. Verify the 1.000 in. × 23-spline hub matches the M5OD input. Check hub, spring, and bolt clearance.
STEP 6 — INSTALL SPEC SF823 PRESSURE PLATE
Position the pressure plate over the disc and SHO flywheel dowels. Install all six mounting bolts. Tighten progressively and evenly in a criss-cross pattern.
STEP 7 — TORQUE PRESSURE PLATE
Torque the SPEC pressure-plate bolts using SPEC's SF823 installation specification, not a generic clutch torque value.
STEP 8 — CHECK DISC CENTERING
Use a 1.000 in. × 23-spline alignment tool. Verify the disc is centered and the tool enters the pilot bushing freely.
STEP 9 — PREPARE M5OD-R1
Inspect the input shaft, pilot nose, front bearing retainer, release-bearing guide area, input seal, and transmission face. Install the selected M5OD hydraulic release assembly.
STEP 10 — PILOT ENGAGEMENT CHECK
Move the M5OD straight toward the engine/bellhousing. The input pilot must enter the bronze bushing smoothly. Do not use bellhousing bolts to force the transmission into position.
STEP 11 — BELLHOUSING SEATING CHECK
The transmission/bellhousing faces must seat fully and metal-to-metal. Any unexplained gap is a STOP condition.
STEP 12 — CONNECT HYDRAULIC SYSTEM
After release geometry is confirmed, connect the hydraulic line and selected master cylinder. Bleed the system thoroughly.
STEP 13 — INITIAL FUNCTIONAL CHECK
With transmission in neutral, rotate the engine by hand and check for scraping, binding, or interference. Operate the clutch hydraulically and verify release.
1989 SHO 3.0L → M5OD-R1
CLUTCH CONVERSION BUILD & INSTALLATION SPECIFICATION
Off-Road / Race Truck Application
1. Project Objective
Convert the stock 1989 Ford Taurus SHO 3.0L DOHC engine to an M5OD-R1 longitudinal manual transmission using the existing SHO flywheel, a high-clamp SHO-specific pressure plate, an M5OD-compatible clutch disc, a custom pilot bushing, and a hydraulic clutch release system. The assembly must be physically mocked up and all critical clearances verified before final installation.2. Build Components
| Component | Specification | Status |
| Engine | 1989 Ford Taurus SHO 3.0L DOHC V6 | USE |
| Flywheel | Existing/new SHO flywheel; user-supplied E9DR marking; 8 crank bolts / 6 pressure-plate mounting locations | USE |
| Pressure Plate | SPEC SF823 Stage 3, 1989–1990 Taurus SHO application | USE |
| Clutch Disc | McLeod 260527, 500 Series; 9-11/16 in.; 1.000 in. × 23 spline; sprung hub | USE |
| Transmission | Ford/Mazda M5OD-R1 | USE |
| Pilot Bushing | Custom SAE 841 / Oilite bronze bushing | MACHINE AFTER DIMENSIONS |
| Hydraulic Release | M5OD-R1-specific concentric hydraulic slave/release assembly; Ford 9L5Z-7A508-A is the current candidate | VERIFY GEOMETRY |
| Master Cylinder | Hydraulic master cylinder sized after slave travel and pedal geometry are established | SELECT LAST |
3. Critical Interface Requirements
- SHO flywheel must correctly locate on the SHO crank and run true.
- SPEC SF823 pressure plate must locate on the SHO flywheel's dowels and mounting pattern.
- McLeod 260527 disc must have adequate friction-face coverage under the SF823 pressure plate.
- McLeod 260527 hub must fit the M5OD-R1 input shaft: 1.000 in. × 23 spline.
- Disc hub, springs, flywheel bolts, and pressure-plate cover must have complete clearance.
- M5OD input pilot must enter the custom pilot bushing without binding.
- M5OD must seat against the bellhousing/adapter without being pulled into position with bolts.
- Hydraulic release bearing must have correct static clearance, sufficient release travel, and no pressure-plate over-travel.
- Input shaft must not bottom against the crankshaft when the transmission is fully seated.
4. Pilot Bushing Design
The factory SHO clutch arrangement does not use a conventional crankshaft pilot bearing. Because the M5OD-R1 is a longitudinal transmission, the SHO crank must provide a pilot support for the M5OD input shaft.Initial design:
- Material: SAE 841 Oilite / oil-impregnated bronze.
- Type: Solid press-fit bushing.
- Initial target length: approximately 0.500 in., subject to actual engagement.
- Bushing OD: SHO crank pilot-bore diameter minus the appropriate press-fit allowance.
- Bushing ID: actual M5OD input pilot-nose diameter plus appropriate running clearance.
- Provide a small lead-in chamfer on the transmission/input side.
5. Installation Procedure
STEP 1 — PREPARE THE SHO CRANKClean the crankshaft flywheel ******. Inspect the crank ******, threads, and rear main area. Remove all burrs and contamination.
6. Final Geometry & Clearance Verification
These checks are mandatory before final installation/operation.| Item | Measurement | Result |
| A | Bellhousing/transmission mounting face → SPEC pressure-plate diaphragm fingers | _____ in. |
| B | M5OD transmission mounting face → fully collapsed hydraulic release-bearing face | _____ in. |
| A − B | Static bearing-to-pressure-plate clearance | _____ in. |
| C | M5OD input pilot-nose diameter | _____ in. |
| D | SHO crank pilot-bore diameter | _____ in. |
| Pilot ID | Final bushing ID based on actual C + required running clearance | _____ in. |
| Pilot OD | Final bushing OD based on actual D + required press fit | _____ in. |
| Pilot length | Final bushing length / available engagement | _____ in. |
| Slave stroke | Available hydraulic release-bearing travel | _____ in. |
| Required stroke | Pressure-plate release movement required | _____ in. |
7. Required Clearance Checks
- Disc friction surface must remain fully within the pressure plate/flywheel friction area.
- Disc hub must not contact the flywheel bolts.
- Disc hub and springs must not contact the pressure-plate cover.
- M5OD input pilot must not bottom in the SHO crank.
- M5OD input shaft must have adequate engagement in the pilot bushing.
- Transmission must seat without force from bellhousing bolts.
- Hydraulic release bearing must not continuously ride the pressure-plate fingers at rest.
- Hydraulic release bearing must provide sufficient travel to fully disengage the clutch.
- Hydraulic release bearing must not over-travel the pressure plate.
- Rotate the engine/transmission through at least two full crank revolutions by hand before first start.
8. Final Build Configuration
SHO 3.0L crank → custom bronze pilot bushing → SHO flywheel → SPEC SF823 Stage 3 pressure plate + McLeod 260527 disc → M5OD-R1 input shaft → M5OD-specific concentric hydraulic release/slave → hydraulic master cylinder.9. Parts Not To Purchase Until Geometry Is Verified
- Final pilot-bushing dimensions/material specification.
- Final hydraulic release/slave assembly if the 9L5Z-7A508-A geometry does not meet the required dimensions.
- Hydraulic master-cylinder bore and mounting configuration.
