Runs Great Cold Then
matty
Southern Cali
I Have A 1994 Taurus sho And Been Having A Issue That Is Driving Me Nuts,When I Start It In The Morning Perfect Nothing Wrong,Then When it Warms Up It Starts Pulsating(Like A 1000 Rpm To 400Rpm)just as an example so YOu Can See The Rythem.And When I Shut It Down It Doesnt Want To Start Back Up,Unless I hold the gas pedal to the floor,but once it cools down everything is perfect,and starts right up..
itwonder
VA
I'd start with the idle reset procedure, run KOER and KOEO tests, and check codes. Then I would clean and inspect the IAC. Is there any misfiring or roughness associated with this?
matty
Southern Cali
ill check those,the water pump has been done front 60k plus clutch and rod bearings.
itwonder
VA
Unfortunately, you can't completely rule out a WP or CPS after doing a 60K. I had a Cardone WP that was installed during a 60K fail after 200 miles.
matty
Southern Cali
thanks for your imput it was the cam sensor not to bad to replace and there wasnt any oil on it so i didnt worry about the seal.
Satchmoz
