rod / main bearings help
oneqwicksho
cleveland, ohio
Ok I just put a new front seal in my sho and timing gear and timing belt and the reasons for doing this is the seal started to leak and once it started to leak a slight engine knock started so I pulled it in the garage got the parts and my s40 pvc to press seal in put all back to geather and noise still there I thought it was from the timing being off a tooth but it aint. So I'm wondering if its the oil pump or bearings it had a 60k done 18000k ago but I don't think they did bearings an it has 128000k on the engine. And when it started knocking I only ran the engine like three minutes enought to get it home and only at 1000( no noise at that rpm) and one minute after changed parts and its a little louder now so how do I tell if I need stander bearing or over sized and how do I check the oil pressure and what is it spose to be
Storm-Chaser
Shit Louis
During the drive home, did either the Oil Low (yellow) or Low Oil Pressure (red)lights illuminate?
:burnout:
