Rod bearings - plastigage
RAYJAY
WHO ME ?
UNION DALE PA
any auto parts store has them found this on there web site
Plastigage
Plastigage is a quick and easy device for checking bearing clearances. Available in four ranges to cover most applications. Twelve strips per package with a measurement gauge printed on each wrapper.
SPG-1 (green) .001 – .003 (.025MM – .075MM) range
SPR-1 (red) .002 – .006 (.050MM – .15MM) range
SPB-1 (blue) .004 – .009 (.10MM – .23MM) range
SPY-1 (yellow) .009 – .020 (.23MM – .50MM) range
naval-avi8or
Chesapeake, VA
Anyone who has used be able to elaborate on the exact process. I.E. with the old rod bearings in/out, How many strips per bearing and where you should place the strip(s). etc.
Here's my scenerio, I'm going to replace the rod bearings while I have my engine out and some what torn down for an engine swap. The motor has 113+K and I have only inspected one cap bearing. It looked fine with very minor wear connecting rod side my not be the same. I no alot of guys are changing there rod bearings and would imagine they are just buying new bearings and instaling them. If you use plastigage and the clearance is out of limits I asume you have to get the crank machined to accept the next size larger beaings. Any insight would be great.
Off Road SHO
Moderator
QUOTE]
The instructions are right on the package (in 3 languages)and very easy to understand.
Tom
rlw001
Reading, PA, USA
It seems to me the purpose of the Plastigage is to ensure the bearing have the correct clearance? So if the Plastigage shows the the clearance is too great or too tight you have to get bearings other than stock size? Has anyone found this to be the case?
Off Road SHO
Moderator
I've done 4 SHO motors myself and found all of them to be at .003 which is the outer limit of acceptable wear with our type of oil pump. We did JesseMachone's 3.0 and he came up with .002 the other day. Great gap there.
If you come up with a .004 or .005, then you should check into a re-ground crank and oversized bearings (expensive way) or go get another motor from a salvage yard (best way).
Tom
myculito
