rev limit in park
kickeralpine
ohio
i have two 94 shos both are atx one hits rev limit in park at 4000 and the new sho i just got hit rev limit at 7000 in park any ideas
yamahaSHO
E85 whore
Arkansas
Open the glove box, push the tabs in on the side, and let the door swing down. You should be able to look in the opening, towards the top and see whether or not there is a chip plugged into the back of the computer.
Do not rev it past 4K in PARK even it it lets you.
If you do, your torque converter won't last very long.
Mr Anonymous
Tire Wall
Vrooooom! My car is faster than yours standing still! :nut:
I've never understood the fascination people having with revving a car in park or neutral...
kickeralpine
ohio
i dont like to rev in park its a new car to me and was checking a few things and noticed it went up to 7000 dont really like it doning that thats way i was asking why it was
S
shoebilly
Guest
Using common sense, the neutral rev limit is 2500 rpm or less.
kickeralpine
ohio
ok easy on the flaming was a question why its doing this its not normal ok. it does not have aftermarket chip in the back of the computer but looks fairly new.
Axianator
I am a banana!
Roanoke, TX
The factory rev limiter for the '94-'95 ATX is 4000 RPMs in park/neutral and 7000 RPMs in drive. ;)
Axianator
I am a banana!
Roanoke, TX
kickeralpine said:
well its doing 7000 in park dont now why
If your engine is truly spinning to 7000 RPMs in park or neutral, then you either a) have an aftermarket chip connected to your computer (most likely), or b) have something amiss with your setup somewhere.
kickeralpine
ohio
ok i looked at the back of the computer and i dont see no chip out the back like somone said it would be and is spinning up to 7000 in park my other 94 atx doesnt do this also seems to lack power runs nice but my other car will **** it
kickeralpine
ohio
could the computer be bad should i try to swap my computer from my other 94 and see what it does
S
shoebilly
Guest
Keep your foot off the peddle in park.
Racer X
SHO Pilot, Retired
Connecticut
If it's not chipped and it's revving to 7k in Park and Neutral, you may have a bad MLP sensor, aka Neutral Safety Switch.
