Huntervf
Bored now
As if my bank account wasn't ****** raw enough, the 93 now has a very definitive pull to the right and all **** kinds of vibration in the steering wheel. As far as I can tell the rack isn't leaking, or at least it's not leaking very much because the PS fluid is always full. The fluid is burnt though, and it's been flushed twice since 2006 so there's definitely something going on internally. I also have the trademark 1993 pulsation in the steering; had it since I bought the car waaay back in 2004, but it does seem a bit worse than before. Or perhaps that's just the tie rods??
There's quite a bit of side to side movement in the front wheels so I know the inner tie rods must be toast (outers were done within the last 50,000 miles, inners AFAIK are original), and I'm getting severe tire wear on the passenger front inner edge, moderate wear on the driver front inner edge. So okay, I think it's safe to say it needs inner tie rods. However, here's my dilemma:
I've never done inner tie rods or a rack replacement, so I'm likely going to have a shop do the work. With money in very short supply, is there much of a difference in labor for inner tie rods as opposed to just replacing the rack? I'm looking at $50 for two inner tie rods, or $94 for a reman rack (with inner tie rods, limited lifetime warranty, + core) from Autozone, so there's not a huge difference in parts costs. If it's not going to be much more in labor for the rack, I may as well just get that replaced since the car just rolled 162,000.
Or, should I just handle the rack replacement myself? I've never done it and admittedly I'm intimidated. Mind you, I've done probably 50 + top and side 60k services and stripped a couple parts car, so I'm familiar with wrenching on the SHO. I just REALLY don't want to get halfway through this job only to discover I'm ***** and then have to get the car towed to a shop.
I should also mention that I'll have to get a couple new tires as well. So much for new years
Looking for help and advice here folks--How tough is a rack replacement? How much can I expect to pay for a rack replacement at a reputable shop? Anyone know the book time on a rack replacement? Or is it going to be much cheaper to just go with inner tie rod ends (if a closer inspection shows the rack to be okay)?
Sorry to ramble, just very confused and frustrated these days
