Replacement for the power steering cooler?
Racer X
SHO Pilot, Retired
Connecticut
Long story short, I just broke the hose fitting off of mine. I'm going to try to find a radiator repair shop in a few hours, but in the event that doesn't pan out, what are my options for it's replacement?
Can I use a small tube and fin transmission cooler? A stacked plate cooler?
Let me know, T minus 7 days until the convention and I haven't even started the car yet. :bonk:
firebat45
Edmonton
Any PS cooler or oil cooler should work in a pinch. Might even be able to use a heater core from something.
****, you could probably just loop the inlet hose to the outlet hose and run it without a cooler, just don't dry steer back and forth on the pavement too much.
SHOtimer
#2910
Santa Clarita, Ca
...I bought a new one from Ford several years ago. I'll see if I can dig up the part number...of course it is probably discontinued.
Found it: F1OY-3D746-A
Good luck!
Doug
Racer X
SHO Pilot, Retired
Connecticut
Given the time constraints I'm under, I went and bought the smallest transmission cooler I could find.
Fingers crossed...
myculito
