Ok, I had a problem with surging power steering, I came to the conclusion it was a worn out rack and pinion(with help from the board). I pulled out the rack and sure enough it looked thrashed.
I put in a reman rack today and it won't seem to bleed out all the bubbles aswell as when I put the front end on the ground it is like I have no power steering at all.
I flushed the pump like they say to, I even pulled the high pressure line off to see if the pump was working,it was, so was the return line.
Did I miss something??? or do these power steerings take a couple of days to purge the air from the system.
When the car is off the groung the steering feels like it should when on the ground, ???? Did I get a bad reman rack?? or did the pump just happen to crap itself at the same time???
Its got me beat!!!
Any help would be great
Thanks
Rod
Its got me beat!!!
Thanks
Rod
