STRider
My 95 MTX developed a miss/stutter and there are no codes (I checked and everything passed). I have run a cylinder balance test several times and sometimes it passes, sometimes it points to cylinder #4 not passing (maybe half of the time). I checked the #4 plug and wire and did not see anything unusual. The plugs and wires (both Motorcraft) were changed about 20K miles ago and there was no oil in the plug wells. Since there are no codes, I’m thinking it has to be ignition related. So I bought some new Motorcraft plugs and was going to change them. I pulled the back three plug wires and there is a lot of oil in the plug wells. So I ordered the Fel-pro valve cover/plug well gaskets.
While waiting for the gaskets, I thought I should probably go ahead and check the valve shims and change them if necessary even though I still have 10K miles before my actual 60K. Since Josh is at the convention, I was going to call OTC to get the tools and then figure out what shims I would need and order them from FPN. OTC is out of stock on the tools until August 12th. Now I am thinking of renting a kit from someone, but I’m not sure whom I should use.
I remember reading something a while ago that ShoShop and SP Motorsports included tools they made that were copied from OTC and are not as good as quality. So I’m hesitant to order their kits. The only other company I can find current info on a kit is CincySho, but I don’t know anything about their kit. Now I’m thinking I should just put everything back together, then do the normal 60K when it is due in 10K miles.
Does anyone know who rents a shim kit I can order that contains new shims and quality tools? Is there anyone in the Kansas City area that has the tools and will let me rent/borrow them? Or does everyone think I should just replace the gasket and wait another 10K miles? I do have something else I can drive while I work on the SHO, but I don’t want it to be down for three or four weeks waiting for the tools/kit.
