masho95
got Zex?
Here's the deal... doing an engine swap on an 89 and everything is ready to go, except when starting to lift the engine we noticed tranny fluid leaking from the passenger side axle. I know it says to remove that axle before pulling the engine but I just thought they said that for clearance issues and I didn't see a problem with it. So we got the tie rod end and sway bar end link off but the lower ball joint DOESN'T want to come out of the knuckle. Car is current supported on the passenger side subframe only with the wheel off, but I don't see that as an issue for it not coming out? Does is sound like we're going to need a pickle fork or whatever tool to seperate the knuckle where the ball joint goes through the subframe?? Any ideas or suggestions are greatly appreciated. Thanks!
Edit: Once the engine is out the subframe is getting replaced anyways, so it's gotta come off sometime.
<small>[ February 24, 2004, 04:23 PM: Message edited by: masho95 ]</small>
