Reichard Ultra Grip Pulleys
sho_sc
Georgetown, KY
TYSHO said:
Look no further! Click here. :evilgrin:
You will need the new ****** as well, doesn't cost much.
I was actually thinking about a larger (better) version of what I have so I don't have to weld on my tubing ...
TYSHO
Earth
If you can find numbers on your HKS [assuming you still have that one from SS], compare it to one of these that flow pretty good and will bolt right up: Click Here
You can get the Vortech products at a much cheaper cost at: www.superchargersonline.com
DDakRT
Mississauga, Ont, Canada
The UPS man knocked on my door today, after grumpily paying $68 Canadian in UPS C.O.D., taxes, and brokage fees (over 60% of that $68 was for UPS Brokage :squint:), I finally have my pulley.
Lupo
Huntington Beach, CA
Hopefully I'll get mine now!!!:squint:
Which size did you get?
Lupo
I emailed, and just got my tracking number, and it shows in transit.
So they should be coming pretty soon for the rest of us.
Lupo
Wohoo! Got my 3.1 yesterday. I have to admit, even though I already got one a while ago, I am still very impressed by the way these pieces look. Excellent machining.
HYPOSHO
Novi, MI
Blower pulleys
Do you still have these or do I need to call Josh. I just found out about them. Thanks!
yamahaSHO
E85 whore
Arkansas
You have to call Josh at Reichard Racing. The were making a few extras. I know they have a few more 3.2" pulleys, which is what I have, and I know they were going to make some extras of the smaller sizes (2.8", IIRC).
MLNIUMFLKN
Salt Lake City, Utah
If they don't have any CCW rotating pulleys left then you could get a CW rotating pulley. They still work really well. I have an FMIC and a 2.90" CW Reichard pulley and I make 16-17 psi @ 7,000 rpm so I don't think it's slipping much at all. I figure I'm losing about 3-4 psi because of the FMIC. A few months ago when I bought mine, they had a 3.1" CW pulley in stock. A good belt really helps too (Dayco Poly Cog, Goodyear Gatorback etc.).
TYSHO
Earth
I know I posted somewhere in here that if you can't get them or were too late to get in on it, you can still modify and use the standard Reichard pulleys to work in the same order as the special made ones. What would be required is to machine down the snout part of pulley, install it the other way around with spacers to now replace the snout you machined off the other side, as you want it on the opposite side. The spacers can be found on eBay for cheap. For $100, you can buy a used Reichard, machine it down, and buy all the spacers you need to accomplish the same results. :thumb:
yamahaSHO
E85 whore
Arkansas
Mega bump!
For anyone who bought a 2.8" pulley in this GB... If you have one for sale, I'm buying.
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
I have at least one size in my bin when I changed sizes. I will check tomorrow and let you know what I have.
Mike
boookboy
