Rebuilding a 3.2
Cocoa,Florida
headgaskets need to be for a 3.2L
other gaskets need to be for a 3.0L
id buy the 3.0L upper gasket set then sell the headgaskets on EBAY
they'll fetch some fair coin,almost enough to buy your 3.2 headgaskets.
whiteman_01
Well-Known Member
Hastings, MN
Thanks for the info. I will email RCM to see if he can substitute the 3.2 gaskets with the 3.0 kit. Thanks again :thumb:
whiteman_01
Well-Known Member
Hastings, MN
Ok, i got a replay from Mark at RCM. He said that the 3.2 upper gasket set is 3.2 head gaskets with everything else being 3.0 stuff.
SHOtimer
#2910
Santa Clarita, Ca
aryanramsey said:
what are the benefits of swapping 3.0 heads on a 3.2?
The rear heads are identical. The front head differs near where the alternator is allowing the 3.2 accessory setup to work. Some people just saw a bit off the 3.2 head to allow it to work with a 3.0 accessory setup. Apart from that the only difference is that the 3.0 cams are slightly more aggressive....but it is easier to swap cams, rather than heads.
Doug
