Rear Suspension
S
slosho
Guest
Would lowering the car have an effect the rear camber? If so would it be detrimental to tread life?
ryancutler
Somerset, WI
get a camber kit to straiten that out...
i think shoshop sells them...
Ryan
[email protected]
Yo Mamma Osama!!
[1992 Silver MTX]
IRT Performance Clutch, Dynomax Exhaust, Lund Tail light Covers, Coneless, K&N
[In Closet]- NOS #5120, red neons, red wheel lights, blazer techs, side marker lamps
[Next]- Rebuilt 3.2 with Ported & Polished Heads, Raised Compression, Stage II Cams, Adjustable Cam Sprockets, Stage IV IPT Clutch, 3 Angle Valves, Upgraded Valve Springs, IPT Coil Overs, Guages (A/F, Oil Pressure, Temp), IPT LSD, 17x7 Konig Caffeines, Nitto 450's 225-50-17, and PP y-pipe
[1993 Green ATX] -4 SALE-
Coneless, 73mm MAF, K&N, Superchip, DynoMax Pipes w/ [Glasspacks (Click 2 See Video)] -- [Another Video], 68mm TB, Removed A/C Compressor, Filled Body Molding (Gold), White Faced Guages, ACCEL Super Stock Wires, Powdercoated & Polished Intake
RStalveyARFF
too many shos
Georgetown, MA
As with any independent rear suspension, as well as front suspension, lowering the spring will change the camber, as there is a fixed point that the control arm swings at. When you lower it, you change the swing angle, which in turn, changes the angle of the tire to the ground. The camber kit will correct this.
Erik
15.57 @ 93.23 and 15.58 @ 92.73
White 91 Bought 5/12/01 128.5k
Mods:
Borla Catback custom bent by Lou's Custom, Cold Air Induction, Clutch, PP, TOB, Pin just replaced, DIN sized switch panel (replaced cup/coin holder), Fog Light Mod w/ 100w driving lights, Lettering filled in: Black, Nokya 80/100w blue beam headlights(Thanks SHOTIME), Painted calipers: Red, Painted intake: White tanks/Black runners, PermaCool dual 12" Electric Fans, Police Grille, Police Interceptor Emblem, Resonator Removed(not by choice!), SHO-NUT Reinforced F & R Motor Mounts, Shortened Shifter, Superchips Module(thanks SHOTIME), Tint @ 35%
Every Possible Option =)
Go Fast With Class
AIM:SkiSalomon & SHOmetheSpeed
rlw001
Reading, PA, USA
As does MOOG, TRW ...
gregr
Orange County, NY - USA
Anyone have a part number or a link to the SHOShop site where we can buy these kits?
Greg Raciti
SHO Forum Webmaster
93 Emerald Green MTX
Performance Plus high flow stainless Y-pipe
Scott 2.5" Mandrel Bent Stainless
Exhaust with Edelbrock mufflers
SHOShop Cold Air Induction
SHOShop Underdrive Pullies (to be installed)
Romar Enterprises Subframe Connectors
SHO NUT Performance Aluminum Subframe Bushings
24mm front sway bar
26mm rear sway bar
Energy Suspension poly bushings
drivinhard
Gainesville, GA
The SHO Shop tubular adjustable rear control arms are simply stock rear arms from a GTP. You can get them at a GM dealer for about 1/2 what the SHO Shop charges. I have a set on my 92, I got the part number in my files somewhere. I'll have to dig it up.
White 92
SR71SHO - racer '89
RJ-92
Crappy NYS
What year? My dad worked for GM for 37 years and also gets a parts discount.Looks like I'm getting tubular rear control arms.
Ron Wazz
Red 92 mtx 106,000
ss y-pipe,
dynomax exahust w/open mufflers,
street/strip clutch,
lt. weight fly wheel,
ss tq limiters,
bored out MAF,
UDPs, ported intake
Konis and Eibachs
