rear strut bushing
thumpida
louisville ky
i have this nic ethump coming from the back right corner of my car when driving. i have heard this can happen if some bushing around the strut goes out. can anyone tell me how to check or where id be able to buy one at or how much.
Yamaha V6
SHO Enthusiast
Rhode Island
Autozone sells the Gabriel Rear Strut Mount for $50 each. Both of mine were clunking away, as the metal bushing had torn from the rubber mount.
If the strut mount is intact, carefully check the tightness of the top strut nut. This nut, when slightly loose, can create a popping noise when traveling over bumps. If the top nut is tight, there is a chance that the strut itself is damaged, but this would usually require an external oil leak. If no external oil, check those sway bar link nuts and bushings and the sway bar frame mount bushings.
