rear strut assembly
sho4life
midwest
im lost, when i put on the socket the whole things turns and cannot tighten. Whats the trick? i did the front struts no problem
93rev2sev
Hockeytown
I grab the verrrry top of the strut's rod with visegrips wrapped in bike tire. That part of the rod never comes in contact with the strut's seals and the bike tire provides plenty of cushion and grip to get the top nut to spec without marring the shaft.
K-Dawg
Treasure Coast, FL
I use a 1/4" drive 10mm (I think?) socket on the shaft, either inside a spark plug socket or with an adjustable wrench on the nut.
notbange
Love fiST
Sale Creek TN,formerly MA
You can undo the spring compressors slightly so the spring is making firmer contact with the mounts, giving the rod a little pressure to stop the crazy spinning. Make sure the nut is threaded on as much as you can by hand, and don't undo the compressor all the way.
sho4life
midwest
thanks guys but now i have to get it done professional because i broke the stud on the spindle to strut assembly. damn rust!!
