Back in the day some said the V6 Duratec had a very similar rear main seal. May also want to check out the 2.5L Contour Duratec motor.
Well the 3.0L Duratec is not going to work. It's dimension for the seal are Width=.427"; Shaft=3.465"; Outside diameter=4.2680"; Bore=4.252IN
The 2.5L Duratec V6 rear seal is Shaft Size=3.625", Housing Bore=4.24, Outer Diameter=4.256, Width=0.39in
Width on the V8 rear seal is 0.35"
