WHAT? The carrier is a piece of CAKE to get off once the engine's out of the car, or the transaxle is out. It's about 10x 10mm bolts, period, and I use a ratchet wrench to remove them. (Did one Saturday for an engine build...)
How much labor does it take to remove the oil pan when the engine's still in the car, vs. how much labor to remove the transmission to get at the rear main seal later?
It's open & accessible. CHANGE THEM BOTH while you can. Yes, change the oil pan seals if you're of the mind to & they're staring at it anyway. 10 more 12mm bolts & 4 nuts & the pan's basically off. Billy is right with one thing (oh my god did I just say that out loud?), in that it's usually the oil pan seals, HOWEVER, if it's not the pan seal, it's huge labor to replace the rear main later.
And yes, I've seen more than one rear main / rear carrier leaking, including the 114k engine I'm refreshing this weekend.
>>"I wanna say that paper gasket is a son of a bitch to get off without power tools & the carrier is easily damaged."<<
Yes, the carrier's as easily damaged as any other aluminum piece that's not handled properly. This brings me to another point - expansion rates of aluminum vs. iron. Aluminum plate bolted to iron block = leaks over time. Also, the paper gasket is a piece of cake to remove. Ever heard of a) gasket remover and b) a scraper?
This is, of course, just an opinion. Is that ok Billy? Just checking with you man, let me know if I'm entitled to it.
<small>[ October 12, 2003, 07:52 AM: Message edited by: Yamaha V6 ]</small>
