1slickRED89
Guest
after thoroughly searching for the fix, and not finding it. I found a way to replace the rear hard brake lines. I have a '94 ATX with ABS
two facts:
new lines are not available from the dealer for any ford cars, let alone the SHO.
it's not really possible to make ISO bubble flares at home. that and they are hard to find premade too.
I ended up finding adaptor plugs to turn the M10x1 and M12x1 into standard 3/16" fittings.
parts I needed where four m10x1 adaptors (two under the hood and two at the rear biasing valve), two M12x1 adaptors (both at the rear bias valve) other things needed are five 3/16 line ends , 25' roll of bulk 3/16" brake line (both front-to-rear lines and pass. rear line), one premade 20" line (dirvers rear line, it needs to have the old rear line end installed on it, because it's bigger).
the only tools needed are the standard flaring tool and a small tubing cutter.
the m10 part number is 1442-1 ($3 each x4) and the part number for the M12 is 1446-1 ($5 each x2). I found them at Murry's discount, but I would bet they are available elsewhere as well.
all told, to reaplace all the rear lines cost about $60. pretty cheap considering how important replacing rusty lines are.
adaptors=$22
25' brake line=$21
5 line ends=$10
20" line=$3
two facts:
adaptors=$22
25' brake line=$21
5 line ends=$10
20" line=$3
