Rear Brakbios valve help
jnrock
96 SHO
Northern Vermont
My rear brake bios valve linkage to the rear control arm is missing parts enough so it is not working. I tryed to push the arm against the switches on it and they will not move.
Am I correct in thinking that if the linkage is hanging down the rear brakes are reduced or not working at all? It feels like they are not working.
Any help anyone would be appreciated.
Yes if there is no physical connection it is the same as the wheels hanging in there air and little rear braking.
I have a valve with the plugs installed bypassing the thing if you're interested.
Mr Anonymous
Tire Wall
Get in touch with Kirk at www.nesho.com in Spencer MA. He can set you up with bias plugs to set the brake bias at a fixed level, or replace your valve & actuator arm with working components.
Satchmoz
