revhardSHO
The top end has been torn down (did notice someone has been in here before) but the shims have never been adjusted. Car has 168K on it, and my plan is to re-use the old shims since everything on the front head is within spec as it sits, so I will just be flipping the shims and going from there. I am re-using the intake gaskets and valve cover gaskets as they look relatively new. Budget build for sure. Re-gaping the double platinum plugs only new part will be spark plug wires. Autozone has them for $35, but at that price I have my doubts. What are people using these days? Something mid-range would be preferable.
I assume this is okay to do, but I just wanted to double check and see if there was anything else I should do before I seal it up again.
