Hey guys... so after my front 60K I have this odd hesitation. I HAVE NO CODES. It happens randomly, I thought it might be the TPS, but then I got to thinking about the grounds. I don't think it would be the plugs or wires, the wells are all dry too, I didn't have the problem before I took things apart. I don't think the timing is off, wouldn't that cause a lot more problems then random hesitation?
I am going to check the grounds when I get home, if that doesn't help I will swap out the TPS.
You guys have any other ideas?
Things I have done;
cleaned the maf
every thing on the front is new, cps, water pump, timing belt, tensioner...
reset the idle
--edit--
Also read about the PCM or DIS going bad...
Things I have done;
cleaned the maf
reset the idle
--edit--
