Radiator fan cfm?
GotSho5390
Houston
Anybody know what the factory fan pulls/pushes as far as cfm? Trying to see if i can get an aftermarket fan to work.
olympic
Saskatchewan, Canada
It's probably in the 2000-2500CFM range. I have a Derale 16" fan rated at 2175CFM and I've never had a problem with it even on the road course.
GotSho5390
Houston
Cool- I've talked to the local SHO fixer upper and we decided to go with a 16 inch from summit racing. We'll see what happens.
olympic
That's where I got mine from, it's a good quality fan. Just don't mount it directly to the radiator core like they suggest if you can avoid it. That puts alot of strain on the fins and tubes and can cause problems. I managed to screw mine to the aluminum "frame" that runs along the top and bottom of the core.
