i run 235/45/17 no problem, I have a tire calculator, because i work at a shop that carries tires let me see here....
stock. 215/60/16 overall diameter 26.2 section width 8.5
convert to : 215/55/17 overall diameter 26.3 section width 8.5
as far as 225/55/17 overall diameter 26.7 section width 8.9
and 225/50/17 overall diameter 25.9 section width 8.9
I'd say you are good to go if you go with a 215/55/17. shouldn't hurt the speedo. there are no changes in overall diameter ..well if .01 makes a difference, and the tire width is the same. just a bigger rim. the other sizes are a bit off.
ashley
