FOMOCOTOSHO
I eat Rice.
Hey everyone,
Just bought my 3rd SHO a couple weeks ago (Red '95 ATX) and it's in a little tougher shape than I was hoping (mechanically that is; the body & interior are still pretty good)
I decided I'm going to pull the motor out because it has quite a few leaks, etc and thought it would be best & easiest to just pull it & start replacing seals & some typical parts. I need your help on suggestions for what to replace when I do it. Here's what I"m thinking so far
1) Plugs & wires (of course)
2) MAF Sensor (had erratic readings & was throwing MAF code)
3) DPFE Sensor
4) EGR Valve
5) Valve Cover Gaskets
6) Timing belt & water pump
7) Timing cover gaskets (including crank & cam seals)
8) Intake Gaskets
9) Oil pan gasket
10) Valve stem seals on intake & exhaust (& perform valve adjustment procedure)
That's about all I can think of. Any thoughts on anything else I should check or do? Or am I going overboard? LOL The car has 132k on it & I'm sure the motor is all original. No idea on maintenance history but I would assume the worst; it runs like shit.
Thanks for your help!
3) DPFE Sensor
4) EGR Valve
8) Intake Gaskets
9) Oil pan gasket
