Problem with OD Light on 94 ATX SHO
artsho
New York
I have a 94 ATX SHO which just had the tranny rebuilt....now the OD light blinks....if I reset the computer it will go away, but comes back after 125 miles of highway miles. If I drive around town it stays off....Only comes on after about 125 high speed driving miles.....If it comes on and I pull over and reset the computer it will go away but again comes back after 125 miles of highspeed driving.....HELP
Bluto
Rochester, NY
Try disconnecting the battery and then turn the headlights on to completly drain the memory storage.
After about 10 mins of disconnected batter/headlight on. Turn the headlights off and reconnect the battery.
I had a similar problem when I had mine rebuilt, but it may be a diffrent scenario.
Slo-Sho
It wasn't me!
Crossroads, CNY
Is it randomly blinking or blinking a sequence of grouped flashes? The trans may be setting a DTC which definately needs to be checked out. Is the car running fine otherwise, TC locking up, etc.?
artsho
New York
I reset it with a craftsman code reader...It runs fine and shifts good....although it does run better when the light is not blinking.....it is a steady blink......Owners manual says to have tranny serviced when this indication appears...tranny shop has no clue..... shrug
projectSHO89
SHOless In St L
Instead of just resetting the indicator, read your KOEO codes! There is probably a code set that relates to the transmission or one of the sensors/actuators upon which it must rely.
Per the service manual, a flashing O/D light indicates that there is a DTC (Diagnostic Trouble Code) set and that there is a transmission concern.
Steve
Chris Benvie
Every so often
RedSox Nation
Your tranny is junk again, i had this happen in my ATX 4 times, each time same result, time for a new one..
take it back to the tranny shop, get your money back and give doug lewis a call.
91 Plus
Well-Known Member
Monroe,Michigan
Yes I had the same problem...It is basically the same as a check engine light but for your tranny! I went through alot of trannies and never got it right!
SHO#7
Cincinnati
Fords are good for eating MLPS's or range sensors. If the transmission is working ok, look at the Data Display on your scanner and watch the voltage on the MLPS ( Mulit-lever-position-sensor ) It should start around 4.5 volts and lose .5-.8 volt ( or so ) with each move of the selector. ( example Park = 4.5 Reverse = 3.8 ETC... ) You may also start to get harsh shifts when the OD lamp is flashing. Sometimes the EPC ( electronic pressure control ) will defult to full line pressure when this happens. Also, check the codes. Because it could be setting another internal codes. I hope this helps out. Good Luck.
artsho
New York
The MLPS's or range sensor was the problem....I find it's a must to check this after a rebuild.
ocso650
