tbone
I'm planning on changing my power steering fluid using the "turkey baster" method where you suck out the old PS fluid from the PS Reservoir and then refill the reservoir with new fluid and repeat every few weeks until the fluid looks new.
I've read of people flushing their power steering completely and refilling it using a synthetic ATF fluid such as Mobil 1 ATF or Amsoil ATF. Because I'll just be removing some of the fluid, My question is, Can I mix the Synthetic ATF fluid with the original Mercon ATF in my SHO.
I just want to know if Synthetic ATF fluid will safely mix with the original Mercon ATF fluid in my car or if I'd need to completely drain the old Power Steering fluid to use Synthetic.
Thanks!
Thanks!
