power door locks not working right
SHO Fan
stamford, ct USA
Hey guys I'm looking at an SHO, a '95. the power door locks will lock all the doors but only the driver's door will open. the others have to be opened manually. could this be fixed with something as simple as a new switch or does it run deeper? If anyone has had this probably or think they have a solution please let me know. Thanks everyone.
SilverSHO
cartersville
Probably the switch contacts just need cleaning. I had problems with my door lock switches, and some alcohol on a Q-tip solved the problem. It worked for my window switches, too, but not too well on the left rear door switch or the driver's left rear switch.
Most likely the driver's door power lock switch, but to confirm that, check to see if the passenger side lock switch operates all four door locks. If that switch operates all four locks then the driver's door switch needs the contacts cleaned as said before.
