Post pictures of your foglight switches
MeeSHO
SHO Owner
York Springs, PA
I have mine on a lighted rocker switch. It is in a row of four switches, amp, neon, foglights, and a switch that lights a custom SHO on my guage cluster. The panel is mounted right under the dash by the diagnostic port. Soon as I get pictures I will post.
ricky
sharpsburg,nc
sorry no switch fogs wired with parking lamps, driving lights wired with high beams. 98SHO
venom
Rowboat Design
Toledo, OH
99V8SHO:
I want to see how you guys with foglights are mounting your foglight on/off switches.
Thanks.
Get the headlight switch out of a contour or a ranger/explorer with fogs. What this will do is give you another contact out of your headlight switch. If you go in your SHO and turn the lights on and then pull out the **** will pop out about 1/8" If you have the switch from a contour or truck that has fogs that is how you turn them on. Their switch and ours are physically identical except the others have the connection to hook up your fog lights to.
I have not done this but I know it has been mentioned by a few others as having been done, sounds like a breeze, and no drilling in any interior components.
MilTownSHO
Horicon, WI
venom:
99V8SHO:
Thanks.
I thought about the EXACT same thing
97V8SHO
V8's Own ALL!
Oklahoma
I don't have switch on mine either, I bought the one with a remote :D so no wiring for me.
wild01ride
Back in time...
Plymouth, MI
venom:
The only thing about this is that the foglights will only come on with the headlights unless you modify the switch and location of the foglight hotwire. I made the modification to my F-150 to enable it to actuate the foglights with only the parking lights on- but it does require a little custom modding of the switch.
As for my White '98...
I'm a little unhappy with the cleanliness of the outline, but the mounting surface was a little awkward underneath the dash and it took a lot of trimming to get it to sit right in the hole.
I think that I'll try to come up with a bezel for it to cap off the mounting.
wild01ride
Back in time...
Plymouth, MI
BTW, the switch is switched on hot with the parking lights. (when the switch is "on", the lights will turn on with the parking lights or if the AutoLamp turns on).
