Possible CPS problem, Need advice on making roadtrip
rct_19903
Tennessee
Hello everyone, is what I know. Any input would be greatly appreciated.
92 mtx
Error codes given by a local mechanic last week, explained by Hawkeye18
219 = Spark timing defaulted to 10 degrees, spark output circuit open.
452 = Insufficient input from VSS.
528 = Clutch Pedal Position switch circuit failure.
542 = Fuel pump circuit open, EEC processor to motor ground. (just means you stalled the car at one point)
Intermittent dying on long trips and the occasional no start.
Back story time:
Six months ago I drove from Space Coast Florida to Chattanooga TN, via North Carolina on my way to college. When i first got to NC, after ix hundred miles of driving or so, the car just quit. it would crank back up after five minutes or so, then after maybe two miles it would die again. A mechanic there had the fuel filter replaced, suspecting dirty fuel. After the replacement and sitting in his garage over night it started fine, and drove me a couple hours down the road, but when I pulled off in a parking lot it died again. Opening the hood to inspect, I found that when the radiator overflow reservoir was replaced, the overflow hose was not put in correctly, and had gotten bent around and was pouring water on the alternator. I fixed that, but soon after the alternator died, and then replaced that. All those problems seemed behind me.
Now, last week, making the trip home for the holidays, after four hundred miles my car dies the same way in Jacksonville. It coasted into a mechanics parking lot, who told me he encountered a Taurus with the exact same symptoms four years ago, and finally found a service bulletin from Ford explaining that there was welding slag in the tank that needed to be flushed out. It was able to start and run an hour later, so we drove it home, and dropped the tank. It was perfectly clean. While we were there we decided to replace the fuel pump.
It seems to have improved a little, but it still has the occasional no-start. It appears that opening the gas cap to relieve vacuum/pressure helps.
Now, after much searching, I'm suspecting the CPS. The local mechanic claims he needs a five hundred dollar specialty tool due to the DOHC, so he won't touch it. The local Ford dealers say it will run $600, which is a little much to swallow. I am considering trying to limp it back to school, where I will attempt to get help working on it from the Automotive Maintenance Department of my school. They seem to be well equipped, but I haven't got a chance to get in touch with them yet.
I need to leave to get back to school at the latest Sunday, preferably Thursday or Friday.
So my options appear to be:
~Ford dealership: $600
~Local Mechanic: does anyone know an experienced SHO mechanic in or near Melbourne Florida, or Chattanooga TN?
~Work on it myself: Special tools? Is there anyone in the Chattanooga TN region who has done this before and is willing to help?
Thank you so much, sorry for the book
Keith Turner
Kens1992mtxSHO
The Commonwealth
Save yourself some money and do it yourself. There are no specialty tools needed. Below is a website that gives you step by step instructions and tells you the tools needed.
SHO Phoenix
93rev2sev
Hockeytown
Get a SHO mechanic from this forum to fix it.
The crank sensor itself is only about $40 but you will probably need a water pump (another 50) and a timing belt (another 30) too.
I would aquire the parts and start lookin' for someone to install em. no use paying marked up garage part prices.
rct_19903
Tennessee
I would happily do the work myself, but I wont be able to until 600 miles down the road in Tennessee. Any feelings about that kind of trip?
SideSHO09
Ca
Get the parts yourself and pay an experienced mechanic a flat rate for the install. a really good and careful mechanic can do the work for you unless you have a little mechanical aptitude and ability to follow the instruction on the internet. would definately get that fixed before the road trip. same problem with mine and i will not be taking it to phoenix in february without fixing this problem.
Waterclown
Philadelphia
Don't do it. Just don't do it. When that sensor goes the SHO is little more than a glorified JVC on wheels
Frisbeeguy
Texas
I drove Toronto to Dallas w/ a bad CPS. The car would die anytime / anywhere / at any speed. An hour later it would just start up & go. It conked out in some bad & potentially dangerous places so fixing it ASAP is the best plan.
Unless your pretty good w/ a wrench & have the tools you need a friend for this repair. It's expensive in a shop but a good mechanic is worth it. As a fellow poor boy I used the above link for directions and did a CPS & water pump replacement on my '89. (I have tools, jacks & stands and a workshop)
Search this forum & you'll find lot's of threads pertaining to this problem.
myculito
