Plus spoiler plus more....
SV&HOdan
Pittsburgh PA USA
Used parts:
1 '91 Plus spoiler faded green $125 (SOLD)
2 91 Plus hoods $125 ea (1 still available)
2 rod shifters + brackets $90 ea
2 '95 hard button EATC $45 ea
1 near perfect '91 mocha steering wheel $75
1 mtx transmission $275
1 set of mocha seats (1991)...nicest I've seen $300
1 '95 MTX throttle cable, $50
New old stock (NOS) parts:
1 Motorcraft spark plug wire set (3.2) $175
1 Gas tank still in box...F4 part number
2 Motorcraft 18 in wiper blades $10 ea
2 sets of Motorcraft front pads (89-93 & 94/95) $20 ea
1 Police grille, new unpainted in Ford box. $135 (SOLD)
1 RH cornering light assembly for '89-'91 front bumper
1 Ignition and 2 door locks (with keys) F0DZ-5422050 B, non lighted
New miscellaneous:
1 ShoSource equal length catless Y-pipe, $200
3 3.0 Head gaskets $50 ea
1 Valve cover set $60 (SOLD)
1 Rear main seal gasket set $20
1 Crankshaft front seal set $20
1 set of new cylinder head bolts $35
1 Bent resonator pipe $80 (Sold)
1 mtx radiator $75 ( SOLD)
1 Dayco timing belt $20 (SOLD)
pair of outer tie rod ends, usa, greasable, $30
pair of inner tie rod ends, $30
Shipping is not included in the prices.
I usually use fedex ground.
Hoods and seats would have to be picked up.
Can email pictures now...
Thanks for looking,
dan
pitaSHO
Why do I do this to myself?
Lewisville, TX
If the rear main seal is a Ford I'll take it. Is the water pump a complete unit or just the nose?
Chris K.
boat
Likes blue ones
Tallahassee, FL
Dang, Chris, beat me to it on the rear main. :p
If the front main is Ford, I'll take it. PM'd
Chris K.
pitaSHO
Lewisville, TX
I'll take the water pump. Is the rear main a Ford seal? Please PM me your paypal address.
SV&HOdan
Pittsburgh PA USA
89 seats
I'm pretty sure I have an extra set of 50/50 rears with just a little bit of
sunburn at the top. No fronts at the moment.
Irish Pride
Irish Inside
MusicCityUSA
The Boot arrived today. It looks awesome! Yet another purchase from Dan that has met 100% of expectations. Thanks!!
pitaSHO
Lewisville, TX
Water pump came a few days ago. Thanks, Dan!!!
Also, I'll take the valve cover gasket set, too. I knew I should have grabbed it with the water pump, but oh, well.
Chris K.
jmszkutnik
89&95SHO
Temperance, MI
Hey Dan,
Is the "bent resonator pipe" the item i need to install a rod shifter in my '89 to replace the cable shifter?
