Please Verify This Part Number
DougLee25
Hatboro
I did a search and came up with the part number for the water pump gasket set of ES 70425. My question is, does this gasket set include the O-rings and a flat gasket for the inlet tube? I wasn't sure if the inlet tube was a flat gasket or not. Something like this picture.... Thing is, this gasket is referenced as the thermostat gasket. I know damn well that the thermostat gasket doesn't look like this though.
The gasket I'm looking for goes here....
Thanks for your time.
Doug
<small>[ February 10, 2003, 06:51 PM: Message edited by: DougLee25 ]</small>
pjtoledo
'ol man in the SHO
toledo,ohio,usa
There is nothing special about the inlet tube gasket. If you have to, just buy some bulk gasket material and cut one out.
Perry Toledo,Ohio
DougLee25
Hatboro
I totally realize that, but I am still wondering if the gasket comes in that set?
LaTechSHO
Louisiana
yes it does...... and if you look at the picture it says "representative image".... from the looks of it came off of advance's website....
that part number is correct
Louis
DougLee25
Hatboro
Thanks people! I just don't want to tear it apart, have the parts store shut down, and not be able to get parts. Figured I would check now. Thanks again.
Doug
Unless that inlet tube gasket is leaking, why would you want to take that connection apart? There is no need to disassemble this joint for any maintenance other than to replace the gasket. If it ain't broke, don't break it.
DougLee25
Hatboro
I know for a fact it is leaking there, that's why I need the gasket. I figured since I'm in there anyway, I would replace the O-rings as well.
Doug
