Plastic suspension piece????
zacritz929
slowSHO
toledo, oh
What is the white plastic piece that connects the stabilizer bar to the strut? it runs up and down and mine is broken on my front left wheel. I looked on Rockatuo.com and couldnt find out what the part is called. I can get a pic if needed.
CerberuS
300 HP N/A SHO
Granby, QC, Canada
many names
-Stabilizer bar link (or linkage)
-Sway bar link (or linkage)
Probably that the new piece will be in metal , i think the original ones were in plastic.
zacritz929
slowSHO
toledo, oh
CerberuS said:
many names
OK thats what i figured thanks alot
DDakRT
Mississauga, Ont, Canada
Yep, should be under stabilizer endlink or something close to that effect. Appearently the plastic ones are better than the metal ones. The Windstar ones also fit from what I've read.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
I thought the concensus on the plastic vs metal, was that the plastic was lighter? I don't think one is better then the other. One just lasts longer then the other.
zacritz929
slowSHO
toledo, oh
shobote said:
get the Windstar aluminim endlinks rather than the plastic ones to avoid another breakage....
what year windstar would this be off of? would this be on rockauto?
ty
shobote
Naperville, IL
well, since he already broke one of the plastic ones; does that not make the metal ones better ? flying through a high speed corner and having the plastic link give way would put you in the ditch for sure. They don't break when just cruising or going straight down the road at high speeds.
Rockledge
Pluggin' away
Connecticut
The Windstar links are aluminum. So the difference in weight (between them and the plastic ones) is a non-issue.
