Goulash
Hello all -
I just bought some Pilot Foglights, hoping to direct install them, but I'm having trouble with the wiring. They're standard 12v, 55W lights with a white power and black ground wire. I thought that I could just splice them into the existing wiring and be good to go, but they won't turn on. Do I need to wire both lights for them to work? I've tried lots of combinations to try to get them to work, and nothing seems to do it. I can do some rewiring if necessary, but mainly I'd like to use the stock switch. The lights came with a standard rocker switch for power, but it's UGLY. Can I use their wiring with the existing switch (assuming they won't splice in?)? Any help would be appreciated, since I'm pretty ignorant when it comes to electronics (the lights do work though when connected directly to the battery...)
*EDIT* - It might help to mention that it's for a 93 ATX. Why is there an extra pigtail between the original lamp and the harness?
- Justin
- Justin
