Kilty423
Sho-fer
Do you have to use powder coat paint to paint the valve covers or can you just use regular high temperature paint?
wifeofSuperHO said:we used 98cent a can walmart spray paint...... no problems with that either.
Mr95Gl said:Really? How's it holding up to the heat?
NotSoSlowSHO said:Im pretty fond of Duplicolor Wheel paint. VERY tough stuff. Relatively high temp, and resistant to chemicals.
Here is my intake and valve covers painted with it, at the time the photo was taken, it had a bit over 3 months of driving with it. And even now, more than a year later, it still looks fantastic.
What did you do? Sand and spray? How many coats? Lastly, what's the name of that paint color. . . thanks!wifeofSuperHO said:fine, we use that "ColorPlace" paint for just about everything including the rim's on the 95... i have to make a small edit though, now our valve covers are painted with tester's Model enamel they come in prettier colors. but the walmart paint works just as good as "heat resistant" paint....
Thanks!Mr95Gl said:Good lord that thing looks great!What did you do? Sand and spray? How many coats? Lastly, what's the name of that paint color. . . thanks!
yamahaSHO said:This is DupliColor Engine Enamel...
This is DupliColor Truck, Van, and SUV Paint...
This is powder coat...
They all look good.
NotSoSlowSHO said:Thanks. It impressed the **** out of me, thats for sure.
Not a whole lot of prep, mainly cleaning. No sanding what-so-ever.
I think I gave it 3 thin coats, with just a few minuted in between coats. The duplicolor paint is awesome stuff. Lays down very nicely, and cures fast and hard. ****, Ive painted a few items (like the rear surge tank braces) that were still caked in a bit of grease. This paint went right over it without fish eyes
Its good stuff.
I dont remember the name of the color. Fortunately (and unfortunately) there are not a whole lot of colors to choose from in the "wheel" specific Duplicolor. I just wanted a paint similar but with a bit more sparkle to stock, and this stuff worked out great.
Silver95 said:I always liked your intake. Exactly what did you do to make the end results? Clear coated after or no?
PAracer said:Using a clear does add a certain amount of depth. I would caution against using it over white paint, though. It has a way of yellowing when used over light colors.
I spent a few hours sanding and smoothing my intake and cam covers. This plus clear coating resulted in a glossy ond deep appearance.
