Painting Ground Effects
DHMag
Free At Last
InCahoots, Texas
im contemplating about rehabilitating my ground effects but need some more education on painting plastic.
my ground effects have flaws (chips, scratches, knicks). should i remove all of the factory paint, fill in the deep spots, resand, then paint ? or just fill in the spots, rough sand, fine sand, then paint ?
if i need to remove all of the factory paint, what could i use to do this safely without affecting the integrity/rigidity/smoothness of the plastic ?
and lastly, i think....what kind of paint should i use ? since the plastic can flex, would i need acryllic paint ?
teach me, and i will learn.
TIA
TrueBlue
Rocket Surgeon
Angola, NY
It's urethane plastic. You'll need a flex-additive, I'd shoot urethane paint over it. I etched the urethane with 220 grit sandpaper, then paint with urethane primer with the additive in it. Sand and paint from there.
PROPHET
Well-Known Member
Tonytown, Texas.
I believe you can purchase some thick black film that you can stick too the ground effects something like the newer Volvo wagons use, i like the look ive taught about doing it to my SHO, it would protect the effects and not hide them altogether as it would be like 5 inches from the bottom of the ground effects.
