p0299:00-68 3.5 ford Taurus 3.5 ecoboost sho
shaldaya
Utah
Є шанс, що ви говорите англійською? Це практично єдина мова, якою тут розмовляють
SHOrod
Torrie Tuned
Cedar Rapids, IA
Have you checked all the intake tubing to make sure it's all properly fastened and there are no leaks? Do you have access to a smoke machine to test for leaks?
-Rod
shaldaya
Utah
I think I had a similar issue, and i found that a vacuum line came disconnected
Mine that disconnected was just under the engine cover on the right side of the top of the engine
check hoses attached to the wastegate controller atop the manifold. iirc, 3 small diameter unclamped hoses that can come loose as mentioned above.
Denis Oleksenko
Kitchener, Canada
Чи перевірили ви всі впускні трубки, щоб переконатися, що всі вони належним чином закріплені та немає витоків? Чи є у вас доступ до димової машини для перевірки витоків?
-Род
had access to the smoke machine, nothing was found
SHOrod
Torrie Tuned
Cedar Rapids, IA
The Car Wizard, on his YouTube channel, recently had a segment on a Lincoln MKT EcoBoost with the Underboost code. In that particular case it wasn't good news. You may want to look it up and check for the symptoms he discusses.
-Rod
