92ShoOff
So it started off with a misfire a couple of weeks ago. I had code P0301, cylinder #1 misfire. Replaced the #1 coil pack and the car went back to being full of power. A small amount of mileage (maybe 20 miles) was put on the car afterward, and I get another CEL. Took the car to AutoZone again and got code P0174.
I bought some MAF cleaner and sprayed the two MAF wires, following the instructions on the can. Unplugged the negative battery cable to reset the computer, let the car idle for a few minutes and the light came back on.
I'm not noticing any symptoms from this. No lack of power, no rough or unstable idling, nothing. I did just have the intake manifold completely torn apart, but all gaskets were replaced, all bolts were tightened, all hose clamps on the runners are snugged down, and to my best knowledge all hoses are reconnected. The hose coming off the front valve cover was split were it slides over the ******, and I did RTV that when I reinstalled it. It wasn't a long split, maybe about 3/8" long at most, starting at the end of the hose. I'm pretty sure the length of the split probably isn't even as long as the ****** on the valve cover, so nothing should be leaking but that surely is one place for me to double check.
Something else has me thinking that I may have left something out when I reconnected things on the back side of the intake manifold, between the manifold (surge tank) and the firewall. I'll double check that as well, but does anyone else have any other suggestions? Is a bad O2 sensor a possibility or is that not possible with this particular code? Any other advice would be greatly appreciated!!!
