okay...think I have narrowed it down
Rio
West Bloomfield, Michigan
Today when I got home from school...(Mom is pickin me up ad droppin me off)...I went to inspect the SHO...I JUST HAD TO!!! I took 2 long straws from these large UofM mugs that my mom bought since I got in.. shrug ...and taped em together.
I went and started the car...and suprisingly i did not sound all that bad, and my silverstars looked brighter than ever against the garage walls. I lifted the hood and proceeded to search for the knock. I then looked under the car and there was ALOT of oil under the car. I mean ALOT...i put my hand on the oil pan and pulled back a palm fulla' Valvoline oh_my However, I checked the oil level, and it was exactly where it should be...
I could also feel the knock against the pan, so I am guessing that it is the bearings. I really think that it is the bearings based upon the large amounts of oil on the pan/y-pipe as well as the oil on the ground eek! But, am I correct in my assumption? what else could this be attributed to? :confused:
thank you all for ALL of your help thus far, and I would like to thank you all for the replies to come.. :)
<small>[ February 24, 2003, 09:52 PM: Message edited by: Rio ]</small>
SHO--ripper
928 Euro
winsted,CT
Did you ever have a leak around the oil pan before? If so you might need a new oil pan gasket. Sounds like the bearings if you can hear the noise best from the oil pan. Hopefully it is the lower ones because you just need to take off the oil pan and could replace the leaky gasket while down there, **** two birds with one stone. :D i really hope for your sake the crank isn't that scored cause if it is you will probably need a new engine. :mad: Good luck.
Worn or damaged connecting rod bearings do not cause an external oil leak. They cause a knock until they seize on the crankshaft. You have another problem that is causing the leak. You will have to find that one too.
MeShoHorny
@dm1n15tr@t0r
NY
Like stated above bad bearings will not cause an external oil leak. Check the oil sensor plug on the back of the oil pan. If it vabrated lose or out that would explain you oil lose.
Rio
YES...i had a leak before, I guess sitting in the same spot for a week and a half would do this.
thank you all very much for the replies...I am going to order the gasket and bearins now...my mom wants me to just take it in to a professional. I know,scott, you have said before that the bearing job is not all that difficult...whaddaya think? 17 w/NO exerience could handle this job?
When ordering the items from napaonline.com, I found the bearings to be $45 and the oil pan gaset..is this is? "Balkamp Oil Drain Plug Gasket" it is 70 cents?
<small>[ February 24, 2003, 11:39 PM: Message edited by: Rio ]</small>
SHOtimer
#2910
Santa Clarita, Ca
It is not the "oil drain plug gasket" it is the "oil pan gasket". They are acually two gaskets that come in one set.
Doug
projectSHO89
SHOless In St L
You need the FelPro gasket set OS30636R.
You will also need some generic gasket material to make a new gasket for the oil pump. All it takes is a sharp pair of scissors and a few minutes. NAPA stores should have the gasket paper.
Steve
I don't think that the oil pan seal will allow that much leakage whenm the engine has not been running for a week and a half. Most all of the oil is already in the bottom of the pan, below the pan seal. If you have a large leak when the engine is not running, check the oil level sensor.
Rio
okay guys, thanx thumbs_u
I plan on doing the bearing job friday...I will need allof your expertise during the process...i just know it.
revhardSHO
Seattle, WA
Good luck with your bearing job, rio.
I hope your crank isnt tweaked or scored.
I will be replacing all the rod bearings in my 3.2L before she goes in, so let me know how it goes!
silas
FIREMT1977
