Oil Pan back on, new problem
RiceeatingSHO
Travis R
Alabama
Ok, Finished the rod bearings, oil pan is on. I can NOT get that flex plate cover thing back in there!!!!! It is just too tight of a fit, how do I do this? Thanks
Ishodu
You can loosen a few of the bolts that hold the tanny on the engine then pry them apart a little then slide it in there. But normally it has no issues sliding in there with out doing that.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Mine was kind of a pain to get in.. just clean it up real good, and be patient with it as not to bend it up, but it should wiggle up into place.
93rev2sev
Hockeytown
Mine's in a box in the garage...where it's been for over a year. I have had no problems with debris getting in there.
Ishodu
I have never had a issue getting it back in there after the pan was installed, you just need to leave out the 2 bolts from the oil pan to tranny.
RiceeatingSHO
Travis R
Alabama
well, yeah, those bolts are out, it's just too tight of a squeeze in there. the side opposite the starter goes in with a litle tapping, but I can hardly get it started there behinde the starter. I have tried oiling it up, uusing a pry bar and jacking the trasmission up, but to no avail, I may end up cutting the part that goes over the starter off and just using it. I don't know, it seems I always run into a problem like this.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Maybe loosen your front and rear motor mount, and jack up on the passenger side of the motor near the crank. (use a peice of wood.. lol :) )
AREA 91
PA SHO SHOP
Area 91
MTX or ATX.
MTX = starter must be removed, then the dust shield installed.
