Oil Leak help please!!!
shokevin1983
94 MTX Green
Michigan City
Does anyone know what the part number would be in FelPro for the oil filter housing gasket? Or is there even one there? i had a shop look at my car and its coming above the filter itself. Any help would be great. thanks in advance :)
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
I don't think you can get it. It is just a large flat O-ring though. Might want to check out industrial applications.
93rev2sev
Hockeytown
The gasket from your old filter will work. But it will need to be changed out yearly. It's not the same material...................nitril. It's not nitril...but the oem one is.
Probably got the word wrong .... o well IMMA
Dunce emoticon
SHObill
'The Collector'
Rochester MI-48307Detroit
Tom beat me to it! I got that from him! Pull the rubber seal off your oil filter & use a 30mm socket to pull the oil cooler & replace oil seal! Both do the same thing so.....
shokevin1983
94 MTX Green
Michigan City
Great thanks guys i will do that then. I work for a part store and i couldnt find the gasket in felpro thats why i turn to here!!! Thanks again i will change that this weekend.
