Octane Adjust bar
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
What is the deal on this?... I was reading some things about running nitrous and how it might be beneficial to run a few degrees ******** and that pulling this connector will retard 3 degrees. If I am running 93 octane all the time, would it be a good idea to pull this, or does this relate to teh knock sensor, and throw off all of the timing?...
Also would it be a good idea that if I am running N2o that i should pull it before using the nitrous.... it would only be a 75 shot and i havent heard much about this connector...
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
You are correct. If you pull the shorting bar from the connector, the PCM will pull 3 degrees of timing from the total spark advance. That's a really good idea when running the juice without a dyno to check things out.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
does it look just like the spout... it seems the spout is near the back of the engine, by the firewall, and what I found, the shorting bar is near the coilpack... i think i recall a piece similar to that bar located near the coilpack...
frosho
WOLFMAN
Tyngsboro, MA
Yeah, it's the same kind of jumper and connector as the SPOUT. Somewhere under the upper rad hose.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
I found an old post of yours about wiring in a bypass with the arming switch... how did you do that?... did you use a relay and short to ground before the jumper?... like a splice into the wire that was a short to ground?...
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Actually, I just tied into the wiring and used a DPDT switch for my nitous arming switch. When the nitrous is off, the octane bar is closed. When I armed the system, it opened the circuit.
AREA 91
PA SHO SHOP
Area 91
Run 93 octaine gas when you spray. You don't need to pull any timing at a 75 shot setting.
