bigbadfords
This may be hard to explain what is happening but I will do my best here. My car runs great about 75% of the time, but occasionally has very little power and doesnt seem like it has a miss or anything like that. I will give an example to try and make it easy to understand. I can be cruising at 55 mph with rpms at about 2000 on flat road, if I want to gain speed and push the pedal down, the car will downshift and rpms will raise to about 2600, but the car will either gain no speed or very little, feels almost like I am towing something or I am driving into 120 mph winds. I noticed that it seems like it mostly does it in "warmer" temps, when I leave in the morning the air temp is about 50-55 degrees and it never really does it, when I come home from work in the afternoon and the temp is 70-75 degrees is mostly when this happens. I am thinking its either a sensor of some type or my K&N cone filter is getting too much warm air combined with the engine heat. I just replaced fuel filter and made no difference. Any suggestions are greatly appreciated. Thanks guys.
