NPS Nuetral Pressure switch
ChrisR
Las Vegas, NV
Does anyone know where I can get this part, or does anyone even know the part #. Also, does anybody know where it is located on the car? Any help is appreciated.
Thanks
RStalveyARFF
too many shos
Georgetown, MA
The model# for autozone is F460, it's a wells part, and it costs $16.99. It should be located on the clutch pedal, one of two. 1 should shut off the cruise control, and the other should tell the car it's ok to start. Call it a neutral safety switch and you'll probably have better luck Chris.
Erik
15.466 @ 92.56 and 15.514 @ 91.91
202hp & 189.8tq
White 91 "Pearl" Bought 5/12/01 132k
Every Possible Option =)
Mods:
Camber -1 x 4, Caster +5 x 2, Fog Light Mod w/ 100w driving lights, Lettering filled in: Black, LPM(thanks Karen! <3), Modine 2 row aluminum radiator, Nokya 80/100w blue beam headlights(Thanks §HOTIME), Painted calipers: Red, Painted intake: White tanks/Black runners/Gold lettering, PermaCool dual 12" Electric Fans, Police Grille, Police Interceptor Emblem, Port Matched Intake, PRO-FLOW 77mm MAF(Thanks Karen!<3), Resonator Removed(not by choice!), Removed Intake Horns, §**-NUT Reinforced F & R Motor Mounts, §hortened §hifter, §urge Tank Restriction Removed, Tint @ 35%, 2 EL8a Amplified Bazooka 8" Bass tubes (Thanks §weetheart :D)
On the wish list: 3.2 Shortblock, BBB's, GTP tubular control arms, Hi Flow heads, Intrax/Koni's, SFB's, SFC's, SVT Tbird wheels, UDP's
Go Fast With Class
AIM:SkiSalomon & SHOmetheSpeed
ChrisR
Las Vegas, NV
Thanks. I only called it that because that's what it said on SHOtimes (after I ran my codes). Maybey it was Nuetral position sensor? All I remember was NPS. Oh well, thanks for the info.
