Noise from rear over bumps
qwik huh
Harrisburg, PA 17112
Now that I have the front end sorted out (Thanks guys BTW) I need to work on the rear suspension. I have new struts and springs back there.....When I go over a bump I hear a noise from the back end. Almost sounds like something is lose and moves. I checked today and the lower arm bushings were cracked but didnt look THAT bad.....Its a clunk noise....thanks
pjtoledo
'ol man in the SHO
toledo,ohio,usa
You can eliminate the sway bar and it's associated bushings. Just remove the sway bar end links and head for the nearest speed bump to test it. Then try to hit the bump with just one side of the car to pin it down further.
Perry
Satchmoz
