Noise from Acc. Belt Area...
ChitownA34DR
American
Oak Lawn, IL
I have a small metal whine from this area. I have noticed significant loss in power lately ever since this noise started. I have been told it is possibly the tensioner pulley gone bad. I think this problem has led to the systimatic destruction of ever acc. so far. I have replaced the A/C Compressor and Alternator so far. My battery light just came on lately and I think the Alternator is going again. Any ideas? I beleive RI-SHO has the same problem I am having. I am going to replace the alternator for good measure, but if it is not that what could it be?
projectSHO89
SHOless In St L
Get a mechanic's stethoscope (around 5-10 bucks)and use it to pinpoint the source of the noise. Then fix the problem. Have Autozone test the battery and alternator or take the car to a shop and have the charging system checked.
Beats stabbing in the dark....
Steve
SHO-Canada
Sask, Canada
I currently have a bad tensioner pulley, my car sounds like it's supercharged. I haven't noticed any effects on any accessories though.
By the way, the tensioner pulley is a rip-off from Ford, and you can't just have the bearing replaced because it's a 'Ford only' bearing.
projectSHO89
SHOless In St L
RCADDELL: Yeah, a screwdriver will work also! :D
SHO-Canada: I had a "Super Charger" sound effect also on my 89. I diagnosed it tot he PS pump. Purging the air from the PS system cured it!
Steve
89
SHO-Canada
Sask, Canada
projectSHO89,
did yours increase with engine revs? i'm pretty sure my 'supercharger' is a pulley bearing, but ya never know.
projectSHO89
SHOless In St L
Yep. With the stethoscope on the front of the body of the PS pump it was obvious the sound was coming from the pump. I had also checked the idler pullies by putting the stethoscope on the jam nut and listening. That's why I knew it was the PS pump.
It's real interesting listening to the isolated sound of each pully or bearing....
I'm just lucky that it was only air. That pump looks to be a real PIA to replace.
Steve
Glebtihonniaqw
