MSilvabus
No start,loud noise after timing...
Hi I am new to the board an have been searching heavily for info pertaining to repairs on a SHO just purchased. When I bought the SHO it ran but with a loud tapping noise which turned out to be the rear camshafts chain tensioner. I took the manifold an valve covers off and replace the tensioner. I have now put the engine back together and I have nothing. The engine will crank and it will try to start and some cylinders fire it sounds but it bangs out right away. When this happens the starter will sound like it gets stuck and the engine will seize then pick back up. I ran the codes with the engine off and nothing came up. When i replaced the tensioner i took off the timing belt so I could get access to the tensioner. I have triple checked the timing an it all lines up. Both sprockets point up on there marks when the crankshaft damper is lined up and the crankshaft dot is lined up with the block at 5oclock. I also attached the camshafts on the right links to the chain(light colored links). What I have noticed thoe is that the camshaft lobes are all in different locations. I belive the number 1 and number 5 cylinders fire at the same time so shouldn't the lobes be in the same exact position at the same time.
Any help would be greatly appreciated.
